rlw999 wrote:
Veebyes wrote:
Of course you could always get a couple of basic marine radios, pick some obscure channel that nobody uses & go at it that way. Range is going to be basically line of sight, the same as ham 2M or the commercial VHF band radios.
That's just as illegal as using a non-type rated Baofeng radio on MURS bands -- with probably more chance of getting caught if you're near water and the USCG is listening.
If I had to choose between using a non-type rated radio on MURS frequencies or using a type rated Marine radio on land, I'd pick the former.
But fortunately, those are not the only two choices, as there are legal options even if you don't want to get a HAM license (which is easier than many people think it is!).
You can get a type rated MURS radio like the BTECH MURS-V1 if you want to stick with VHF. Or if you're ok with UHF, get a license and use GMRS radios -- GMRS base stations are pretty cheap, so if you mainly talk RV to handheld, you can get great range with a 15W or 25W base station on the RV with antenna on the roof. You can get high quality GMRS radios if you need something better than the cheap blister pack radios available in stores.
I agree, using marine channels on land is a BIG NO NO could be big trouble if you get caught.
