OnaQuest
Oct 01, 2013Explorer
DryCamper11 wrote:
I do not want a solid state relay. They are great for some applications, but my 12v system has seen many spikes and I'm more comfortable with a mechanical relay. I've spent too much time tracking down replacement MOSFETs, IGBTs and the like to repair them.
As for the three normal relay solution posted, that requires continuously powering at least one of the relays. I considered that solution, and I've even got all the relays I'd need in my parts box. I could even use a single relay instead of three and change the switch controls if I was willing to go with a constant normal relay on solution.
Look again. The ON pulse allows the first two relays to pick and hold. The next (OFF) pulse causes them to drop out. NO more current draw. You're not going to get much simpler than that.
I wonder why the Intellitec Monoplex works so well in tens of thousands of RVs, but won't work well in yours?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
