12thgenusa
Jan 22, 2017Explorer
I removed mine and added cross "beams" that divided the area into approximate thirds. I cut the coroplast to match the locations of the added structure, added bolts at the splice and taped over the seams with Gorilla Tape. If you are careful all the holes will still line up. It's now easier to remove and install and you only have to remove the section you want to access.
I have had portions down several times to add wiring, add SeeLevel monitor, repair leaking tanks, etc. You will definitely want to do some housekeeping while you are under there.
