DAS26milesExplorer IISep 29, 2016Removal of water heater plug hard pasteMy friends used MH has hard paste around the plastic Atwood water heater drain plug. Worried the plug may break off when removing it. And how would you removed the hardened paste from the aluminum t...Show More
dougrainerNomadSep 29, 2016https://www.amazon.com/Orbit-Sprinkler-Plastic-Extractor-26076/dp/B000I1RQZ8/ref=pd_lpo_86_lp_t_4?ie=UTF8&refRID=R1D9Z406531Y0GQ00KVW&th=1
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Staple Removal
