Bumpyroad wrote:
DrewE wrote:
On Atwood heaters, with the nylon plug inconveniently located behind the gas piping, the only tools I can imagine working are a 15/16" offset box-end wrench (which is virtually impossible to find) or some sort of channel lock or vice grip pliers type tool (which work, but tend to leave the plug worse for the wear and tear). I think it's telling that Atwood sells the replacement plugs in packs of two.
I had a nifty craftsman 7/8 offset ratchet box end that worked great until the b888888s changed to 15/16 and can't find one anywhere. got a "kit" with two plugs and a cheap flat wrench that works but bought a separate 15/16 also.
bumpy
On my last trailer a four way wheel lug wrench worked perfect to remove the plug.
