DougE's avatar
DougE
Remove Water Heater Plug
Last fall I was unable to get the water heater plug out to winterize the system. I ended up just blowing out all the lines with compressed air but could still hear water bubbling in the water heater tank. I figured the air trapped in the tank would be sufficient to allow freezing without damaging the tank and I guess that worked. However, any suggestions for removing the plug next year? I had a 1/2" electric (battery) impact wrench on it with no luck. I could see the remnants of Teflon tape on the plug so it had probably been out before. What about heating it with a plumbing torch? I've had success removing frozen bolts by heating them up for a minute. I do have an air impact wrench but was reluctant to try it as it's quite a bit stronger than the electric.
  • Could it be possible that someone installed a metal plug in drain hole instead of the proper nylon plug? Without knowing what type of water heater it is we only have conjecture.
    Another thing is the heating of the plug to ease removal. Steel tank is okay but with an aluminum tank, not a good idea.
    Finally, Teflon tape is a sealant, it is not an insulator. I'm of new at this game, I've only been RVing since 1998 and I have only been in the construction trades since 1954 and a General Contractor since 1980 and I have never seen or heard of a pipe plug or threaded connection that did not cut through the Teflon tape and make metal to metal contact. If it were true that it is an insulator, we wouldn't need dielectric couplings.
    Not trying to criticize, just trying to clear up a couple of wives tales.
  • I prefer using an impact rather than a long lever. The impact doesn't cause the whole WH to want to shift and rotate.
  • Suburban water heaters have a steel tank and use a steel plug with an anode rod.
    Atwood heaters have an aluminum tank and use a plastic plug.
    Siggy
  • My plug is plastic and easy to put in and take out. May want to consider a replacement once you get the other one out.
  • DrewE's avatar
    DrewE
    Explorer III
    I guess you have a suburban heater with the metal plug and anode rod attached? If so, Teflon tape is probably counter-productive as you need to have electrical contact between the plug and the tank for the anode to work properly.
    At any rate, a long enough breaker bar will not infrequently work wonders where an impact wrench fails.
    On Atwood heaters, with the nylon plug inconveniently located behind the gas piping, the only tools I can imagine working are a 15/16" offset box-end wrench (which is virtually impossible to find) or some sort of channel lock or vice grip pliers type tool (which work, but tend to leave the plug worse for the wear and tear). I think it's telling that Atwood sells the replacement plugs in packs of two.
  • Is this a Suburban water heater? If so, the drain plug is also the anode rod. And it should be replaced when depleted, typically every couple years, or sooner if using a magnesium rod.
    I would use a 6 point 1 1/16" socket with a long breaker bar to try to get it out. The 6 point socket will reduce likelihood of rounding out the hex head. Apply force in the loosening direction, then apply force in the tightening direction. Keep repeating until it finally gives way. Brute force, whether with the breaker bar or impact, should be the last option.
    And when you put it or a new one back in, do not over tighten it. Those are pipe threads and do not need to be screwed down very tight to seal.
  • It depends on how badly you want the plug out. If you want it out use the more powerful impact, or a really long breaker bar. Also use a 4 point socket if you can. It could have been put in and then tightened until it stopped seeping. Which could have been really tight if the threads were cruddy.
    Before you put it back in clean the threads with a tap, and use a new plug.
