deandec
Jun 03, 2014Explorer
Removeing Ignition solenoid from circuit temporarily
Hello.
My rig is stuck in an inappropriate place and I want to move it without involving towing.
The engine starts, but there is no power to the dash fuses initiated by the ignition switch.
One of those fused dash items is the Allison MD3060 shift console.
Hence I cannot shift the transmission.
If I bypass the ignition solenoid and get direct power to the fuses, I think I can use the shifter and drive the rig to a safe destination.
The solenoid has two ignition wires a small jumper resistor between a ground wire and the ignition wires, and a negative link to the fuses as well as a connect of two negative cables.
I would connect the the negative link for the fuses to the two joined negative cables and bypass the solenoid in order to move the rig about a 10 minute drive.
Once parked, I would disconnect the chassis battery and then the cables until I sourced a new solenoid.
Am I creating a monster or is it really that simple?
