Lenny_K
Oct 30, 2015Explorer
smkettner wrote:
Are you installing in the middle of a long wire run? Or near one end?
If near the end just disconnect the wire and connect to the EMS direct. No cut. Then add a short romex from the EMS to the place where you disconnected. Upon removal just put it back oem.
It will be connected at the end of the run by the panel/converter. My original plan is to do as you suggested but I was looking for some options as it will be a real bear disconnecting the wires at the panel.
Decisions, decisions.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
