SoundGuy
Nov 01, 2015Explorer
CA Traveler wrote:
1. My unit has a bypass switch.
SoundGuy wrote:
Which does NOT truly bypass the unit, only physically removing it from the system does ... time to read your owner's manual. ;)
tmartin000 wrote:
Holy shizzle. You are 100% correct. I try **** hard to keep things looking factory and not have those. A metal box and that's it. I guess there may be exceptions, but there are a ton of addition resistance at each of those connection points. This is what excessive heat will do.
Operate any circuit beyond it's rated limits for any length of time and it's not surprising at all that components will fail as you've illustrated ... but operate within the rated limits and there's no reason to expect failure at all. According to your argument, Progressive Industries, TRC, and anyone else that manufacturers portable surge protection / EMS devices had better remove them immediately from the market 'cause they too connect into the system using the exact same connectors I'm using. ;)
BTW, speaking of "failure" - you might want to downsize that pic you've posted so it meets forum requirements and doesn't cause text to scroll way off the screen. :R
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
