MEXICOWANDERER
Sep 03, 2013Explorer
2nd no need to disconnect
BUT BUT BUT
Watch charging voltage if battery is still powering stuff inside the trailer. 15.5 volts may kill some v-e-r-y expensive appliances and electronics. A 4.5 cent factory charging meter ain't going to cut it, get a digital meter.
The best way is as BFL 13 suggested get a GENUINE 200 ampere minimum rated battery cutoff switch and wire it to the house battery negative cables. Shut the battery off when charging or in storage with a battery maintainer BYPASSING the cutoff switch and run directly to the batteries.
BUT BUT BUT
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
