83trekker
Sep 03, 2013Explorer
MEXICOWANDERER wrote:
2nd no need to disconnect
BUT BUT BUT
Watch charging voltage if battery is still powering stuff inside the trailer. 15.5 volts may kill some v-e-r-y expensive appliances and electronics. A 4.5 cent factory charging meter ain't going to cut it, get a digital meter.
The best way is as BFL 13 suggested get a GENUINE 200 ampere minimum rated battery cutoff switch and wire it to the house battery negative cables. Shut the battery off when charging or in storage with a battery maintainer BYPASSING the cutoff switch and run directly to the batteries.
Or just take the negative wires off the battery when charging if I can get a switch? And I fi do this will the converter run off the gen and still be able to use the 12volt lights?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
