MEXICOWANDERER
Sep 03, 2013Explorer
Or just take the negative wires off the battery when charging if I can get a switch? And I fi do this will the converter run off the gen and still be able to use the 12volt lights?
ONLY if the converter is DESIGNED to do this. Some aren't. Others have so much noise (ripple) it is hard on electrical devices in the rig. Others here on this forum can answer this question by knowing if your converter is an authentic power supply.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
