azrving
May 24, 2014Explorer
Manufacturers usually recommended a wood device so as not to gouge. I always used a wire wheel on the heads. I would just scrape the piston so you dont get a piece of wire brush in the gap at the piston to the cylinder. Its best to run full throttle when mowing.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
