riggsp
May 24, 2014Explorer
If you have the heads off (sounds like you do), spray them with Easy-Off Oven Cleaner, let them set for several hours, respray if necessary (you'll be able to tell if the carbon is coming loose), hose it off with water and blow it dry with an air compressor...make sure you wear safety glasses and rubber gloves.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
