Dave_H_M
May 24, 2014Explorer II
Removing carbon from heads and pistons.
Surely this is RV related since it is cutting into my recreational time. :h
My 2 cyl opposed Briggs in the lawn tractor has progressively gotten noisier. It was knocking sort of like the same music carbon buildup makes when there is no more room for carbon. Sure enough I can see where the pistons were banging on the carbon buildup on the heads.
so Is there a nice and easy way to get that stuff off of the aluminum heads and piston top. I really do not want to gouge around on the aluminum.
I've used a fair amount of Kroil penetrating oil with good results for stuck nuts and bolts. Also Liquid Wrench.
