noteven's avatar
noteven
Explorer III
Aug 09, 2021
Removing clear silicone caulk from exterior fiberglass
I bought a vintage (ok - old) Bigfoot camper that is pretty much in stock condition - as the seller said it hasn't had the Pintrest treatment -
But - the camper has suffered an attack of the Silicone Monster to the exterior - every window, arpeture, access door frame etc has recieved generous globs of clear hardware store variety silicone sealant.
Granted, I think the thing would float - but it does not look that attractive all stuck up with dirt and grime - and my looks standards are not that high...
Anyhoo - I would like to remove the silicone sometime in the future -
Anyone who has done this - what is the best cleaner to remove the silicone residue from the fiberglass gelcoat?
Thanks
  • frankwp wrote:
    Silicone sealant has become like a plague on humanity. It's great stuff for certain uses, but there is almost always a better choice when caulking is required. Even when using caulking remover, it's very hard to remove all traces of the ****.
    You should see me lose my mind when I go to remove a motorcycle valve cover and some DIY person has used it and the crumbs start falling in the engine....
  • gbopp wrote:
    Do a YouTube and/or Google search for removing Silicone caulk.
    You'll get several responses.
    Ya I have done a bit of that. A lot of presenters seem to call every kind of sealant "silicone"
    What is gooped all over this unit is the clearish product found in hardware stores called "Silicone Sealant"
    The first inch comes off by mechanical means.
    I am researching how to remove the residue so I can go back with urethane. Sikaflex 522 UV
  • Silicone sealant has become like a plague on humanity. It's great stuff for certain uses, but there is almost always a better choice when caulking is required. Even when using caulking remover, it's very hard to remove all traces of the ****.
  • Apply acetone, white vinegar, isopropyl rubbing alcohol, toluene, or xylene to the silicone caulking. Spray or rub one of the solvents on the silicone caulking to dissolve it and scrape the area with a putty knife or scraper. Pour water on the area, wipe up the area with a rag, and vacuum it when it's dry.
  • Do a YouTube and/or Google search for removing Silicone caulk.
  • Problem with silicone is you can pretty much never get all of it off.
    If it's not leaking, I would leave well enough alone.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
