SirBenji
May 13, 2015Explorer
Thanks for all your responses!
The solar panel is not mounted, it's portable so that's why it's on the panel. So you just unfold it and attach to batteries. I believe it's 150W? Might only be 100W.
I have yet to find a reasonably priced (under $300) PSW inverter. I'm looking to spend half of that max.
In terms of battery charging, I don't want to have to sit there and watch my batteries. I want a plug in and forget option for a charger. The black and decker is an option since I could just leave it on I suppose.
Solar panel
Yes, entirely off the battery.
I'm good with only 300W, but the pSW inverter is about $220. Significantly more than my $75 option (although undoubtedly better)
I won't be charging with a generator, only shore power.
Combo unit = big $. I'm thinking basic auto fuse box for about $20. They'll be right next to each other and I have lots of space.
Here is a pic of my existing converter. My understanding it's only a one stage bulk charge at 3amps until 12.7v:
Battery bank is about 140AH. Is there a low cost psw inverter (Under $150?)
2oldman wrote:
OK that's weird. 100% of us have the charge controller separate from the panel, and in a well-protected space.
jrnymn7 wrote:
I recommend a psw inverter, regardless.
Your batteries will snear at that 7a charger. Check these out... you'll need to monitor and turn off manually (with your switch):
Megawatt Adjustable Voltage power supply
Even better, buy one of these:
VEC 1093 DBD
MEXICOWANDERER wrote:
What are you going to use to recharge your battery out in the bush?
Solar panel
jrnymn7 wrote:
How do you plan on powering the 12v fuse box? Off the batteries only? This is basically what I do. (Shore power/gennie or inverter runs all the 120v stuff).
smkettner wrote:
You are spending too much on an inverter. 300 watts max. Not just the inverter but connecting wire, fuses etc. all make for additional complexity(mo money). I understand Apple is sensitive to MSW. I recommend Go Power sine wave.
Genius is fine although a bit light for charging with a generator. 30 amp minimum IMO if using a generator. I recommend Progressive Dynamics with Wizard or IOTA with IQ controller.
As long as you are adding a fuse box... get a combo unit http://www.bestconverter.com/4000-Series-Compact-Power-Center_c_138.html
pianotuna wrote:
We need more details on the existing converter. It may well be better than the stand alone charger that you are considering.
How many amp-hours is the battery bank?
I agree with other posters, for the list of items you wish to power a 300 watt pure sine wave would be a better choice.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
