otrfun
Dec 02, 2019Explorer II
Itinerant1 wrote:We're trying to power some portable test equipment. Only have weight/space available for one group 31 sized LifePo4 battery. FWIW, the same scenario could be applicable to someone with, say, a truck camper (with very limited battery space) who wanted to run a very small microwave.
LFP batteries are good, maybe you're expecting more than what 1 100ah battery can perform. What exactly are you using over 100a on a 100ah battery?
In any case, just spoke to a LifeBlue distributor who does solar installs. I asked him about the LifeBlue LifePo4 100ah battery's performance when discharged/loaded slightly above its rated continuous capacity. He seemed intriqued with the question, so he's offered to test a fully-charged Lifeblue 100ah (with a 100a continuous rating) at 110-120a sometime this week. It'll be interesting to hear the results.
Edit: Wow, the distributor just emailed me his test results! Apparently the LifeBlue LifePo4 100ah battery's BMS shuts down the battery with a 110a load after 30 seconds. He did the test several times. It would appear the Renogy and LifeBlue BMS's, both, operate similarly.
Disappointing. On to plan B.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
