time2roll
Dec 04, 2019Nomad
BFL13 wrote:You need a Panasonic 'inverter' microwave.time2roll wrote:
I don't think a microwave has much surge at the start. s/b easy to stay under 100 amps. Only real surge in an RV would be an air conditioner and that is not really a concern if you are limited to one battery.
A "700w" Danby MW we had wanted 1050w input and made the 1000w PSW inverter pull 100 amps as seen on the Trimetric. The inverter showed its overload light but kept running. After a few times doing that, the inverter burnt out some components on its circuit board.
Set to low power these actually draw less current instead of cycling the megatron.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
