BFL13
Dec 04, 2019Explorer II
time2roll wrote:BFL13 wrote:I would not buy any inverter over 1000w to be connected to lithium battery of 100 amp max current. Probably 800w max inverter for best results.
...... and we are ok with the 2000w PSW inverter we have now. Newer MWs will run on MSW (BTDT), but not this 1991 job.
I realize you have more battery but we are talking about a current limited lithium battery.
My point was that AFAIK there is not any MW small enough for that, where a 700w is already 1050w for input.
So Li does not change the basics same as Wet or AGM that you need more than 100AH if you want to run a MW unless there is a smaller size Panasonic inverter type you can run at half power maybe.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
