12thgenusa
May 12, 2014Explorer
greenrvgreen wrote:
The 100 watt rating is based on a 19 volt output at 5 amps and change. But I'm using a cheap PWM controller to harvest 12 volts, or about 62% of the output, as stated.
Sorry, I'm a little thick-headed tonight. After the third repetition, I understand what you are saying.
If the specs are correct, the Renogy panels need 8.62 sq. in. to produce a watt and my panels take over 10 sq. in. per watt.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
