pianotuna
May 13, 2014Nomad III
Hi Mex,
Yes, diversion loading has been discussed. There are 12 volt water heater elements available, and at least some MPPT and PWM controllers do diversion loads.
My existing controller only does a puny 2 amps--but with a "chip" upgrade it can do up to 20 amps.
I believe the Rogue does diversion loads, and the PWM Tristar does as well--but NOT the MPPT Tristar. Morningstar apparently has an add on that can be used for diversion loads.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
