Tom_M1
May 14, 2014Explorer
Homeless by Choice wrote:The individual cells will bend to follow the curve of the panel. I wouldn't make any drastic curves though. I am not going to glue this panel down. I will be mounting the panel in a frame so I'm not concerned much about the heat generated. The heat factor would be a combination of the sun heating the panel and the current flow. I doubt that it would heat up enough to damage the fiberglass.
I was wondering where the panels could be bent (along the seam line between solar cells only?) and what was the minimum bend radius that is allowed for both a forward and a backward bend? I can't find this information or even a discussion on these subjects on any of the sites that I have looked at. Also I was wondering what effect the heat output from the bottom of the solar cells has on the fiberglass surface.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
