Tom_M1
May 14, 2014Explorer
My panels are mounted to the side of my coach and can be lifted off and set out in the sun.
The larger of the two weighs about 30 pounds and is a bit of a struggle getting it hooked back on the side. I'll be replacing it with the flexible panel which is a lot lighter and will be easier to handle. A frame is needed to hang it in the same spot.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
