theoldwizard1
Jun 29, 2022Explorer II
pianotuna wrote:
Hi All,
I'll be "feeding" the unit with #8 wire.
I have a choice of powering from the alternator, or powering from the starter battery (which is of course charged by the alternator), but only with the ignition key turned on. Doing the battery route would eliminate surge on the alternator, so I'm leaning in that direction.
You are OVERTHINKING !
#10 wire is more than enough (I always recommend pre-tinned marine wire - no corrosion).
You want an input that turns off when the key is off. Don't worry about surges. The charger will prevent that.
