pianotuna
Dec 09, 2022Nomad III
otrfun,
The bench testing used #4 wire input and the length was inches.
30 amps in and 20 out is not a measurement of efficiency--because we are dealing with mppt boosting the voltage, i.e. swapping amps for volts.
I've set the unit to 14.7 volts output to maximize charging.
In the RV the wire length is about 12 feet due to the dc to DC having to be located under the passenger's seat. It is #8 wire which is more than adequate for 30 amps input (about 6 feet on input side).
I have seen 16 amps going to the house bank at idle. The highest reading noted was 19.6 amps, when driving. I don't have an easy way to measure input amps to the unit.
I'm more than satisfied with these results and I'd recommend dc to DC charging.
On a disappointing note, Victron, who make excellent equipment, in general, chose to not have a cooling fan on their dc to DC charger. Some reports say it gets too hot to touch after operating for an hour.
The renogy does have a cooling fan.
