StirCrazy
Dec 10, 2022Moderator
pianotuna wrote:
otrfun,
In the RV the wire length is about 12 feet due to the dc to DC having to be located under the passenger's seat. It is #8 wire which is more than adequate for 30 amps input (about 6 feet on input side).
The renogy does have a cooling fan.
hold on here, #8 gage is the bare minimum size for a 2% voltage drop at a max lenght of 6 feet, I would hardly call that more that adequate, thats pushing the limit.
I do remember you saying it was to hard to upgrade the wire so if your happy with it thats fine but Otrfun is right, a larger cable would reduce the voltage drop and lower your inlet current.
