otrfun
Dec 10, 2022Explorer II
pianotuna wrote:Yup, it's surprising how much load some things can take and continue to work.
otrfun,
Back when I first had a 2500 watt inverter, I'd often run the water heater on electric. I monitored voltage when doing so and when it reached 12.2 I'd shut down and allow the battery bank to recover. I found I could sustain a 1:3 where I'd run the heater for 20 minutes and then leave it off for 40 minutes.
I'm still on the OEM alternator.
I've always been a big fan of making lots of voltage and current measurements. Reducing voltage drops and maximizing efficiency & current transfer between components is a pet peeve of mine. If possible, try to go one cable larger than needed with every install. When dealing with 12v DC circuits, I strive for 1% voltage drop under maximum load. In a pinch, I will occasionally accept 2%. Many of the installs I've seen through the years have 5 to 10% drops. Yup, they "work", but not well, or to specs.
