- wa8yxmExplorer IIIWatts out = watts in plus overhead and conversion loss.
A DC=DC converter usually is an inverted/charger paired. Power in is chopped into Square wave A/C and then processed. This is about 90% efficient going in and another 10% is lost going out that's best case. Few are that good.
Now.. some interesting things.. Because it's not converting to 60Hz AC but usually a much higher frequency. the processing is easier and if it uses a transformer that's much lighter.. But basically you have an inverter and a converter in one box. - BFL13Explorer II#8 might not be enough. I had to change my input neg path to use the frame (as a really fat wire) to get my voltage drop small enough to keep input voltage in the 13s. You can tell by if it can't hold that 20 amps output, that you need more input (ie, less voltage drop)
I can't remember the unit's efficiency, but for instance:
14.7 x 20 = 294w and 85% efficiency (eg) needs 346w input.
If input voltage is 13v after v drop from engine batt, 346/13 = 26.6 amps. If you could keep input voltage at 14, then 346/14 = 25 amps
You are supposed to get input from the engine battery, not from the alternator. You need a common ground like it shows in the manual. With a Class C that would be the frame
The unit turns on and off using the little wire that connects to pos input. I have a switch on that little wire in my set-up, and just ran that wire over to the pos input terminal.
You must not also have the OEM alternator charging to house connected like in a MH, or you will add to the amps demand on the alternator, which the DC-DC is supposed to limit.
Pick the nearest charging profile on the Renogy to what your batt spec is (14.7 on mine) and then set your solar controller to match that voltage so they add their amps best while driving down the road. - CA_TravelerExplorer IIIGdetrailer - Thanks for the reminder of watts.
- pianotunaNomad IIIHi All,
I did not do the bench test--my cousin did, so I don't have answers to your questions. I thought it might be useful to others.
I'll be "feeding" the unit with #8 wire.
I have a choice of powering from the alternator, or powering from the starter battery (which is of course charged by the alternator), but only with the ignition key turned on. Doing the battery route would eliminate surge on the alternator, so I'm leaning in that direction.
I'll have the ability to switch the dc to DC off.
I'll still have a "poor man's boost ability, too. - GdetrailerExplorer III
CA Traveler wrote:
Not very efficient. :(
Wonder if it varies by voltage or amps.
Correct.
Each time you do some sort of "conversion" there is some efficiency loss which results in some heat.
Additionally going from a lower voltage to a higher voltage means it takes more current on the input than the current you get on the output but if you check the watts they will be nearly identical minus of course the conversion loss.
For instance.. Say you are converting 12.0V to 14.0V..
12.0V at 30A is 360W.
360W at 14.0V is 25.7A not including the efficiency loss of the switching power supply..
So depending on the start voltage of the OPs test and what his target output voltage it is very possible that his input current can be 30A at the lower voltage but yet only yield 20A at his higher target voltage but yet still get the same watts..
This is no different than what the Power Company does to distribute AC on the grid.. They take the generated voltage, run through a high voltage transformer which boosts the voltage and that drops the current allowing thinner wire to be used. Then at your house run it through another transformer to drop to a more usable lower voltage at higher current for your home. - BFL13Explorer III got mine to do better with a higher input voltage. What was the input voltage on yours when input amps was 30?
Of course you have to have input watts higher than output watts, so what was the output voltage when it was doing 20a?
I run my output set to 14.7v and it does the 20 amps out steady. I had to improve the wiring from engine battery to Renogy input to reduce voltage drop and so keep input up enough. - CA_TravelerExplorer IIINot very efficient. :(
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
