red31
Sep 10, 2013Explorer
I suspect the controller is not working, try this, while all hooked up measure the panel voltage at the controller and compare to battery voltage, they should be nearly the same. If the panel measures high, well, directly connect the panel to the battery and disconnect in the upper 14s!! You are the controller.
