brulaz
Aug 25, 2014Explorer
BFL13 wrote:
They get 15+ sometimes as a special procedure when the inverter is off and battery disconnect is on too so fridge etc don't see high voltage. (Equalize routine similar)
This what I try to do. Trailer came with a switch between the WFCO converter (and DC distribution panel) and the battery. So anytime I equalize (>15V), I throw this switch and the WFCO, and all appliances fused through the DC distribution panel, get disconnected from the batts. If there's no switch, you could just disconnect that cable from the batts.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
