BFL13
Feb 28, 2021Explorer II
No worries, thread is open ended. But the Renogy only cuts the current in half, and what if that is not the right amps? The dial a current add on would work with Victron or any fixed current charger.
Mex is the guy for such things--he uses light bulbs in the line. A dimmer switch isn't it? Not sure how they work. you want the same voltage but adjustable current. Portable chargers have current settings like 4/10/20/40 you can choose, but you want a dial any amps.
I will be looking at the input side when I do the proper installation--I didn't feel for hot spots at the time. I want to use the 7-pin for the signal lights etc, but by-pass the connections through the pin# 4s. That would mean another quick-connect for that one wire for when you slide off the camper. The ground wire would still be through the 7-pin (for the signal lights etc), but reducing R of just the pos wire would help the circuit's total R.
I didn't leave it running long enough to know if the house battery would reach the Vabs set at 14.7v. Have to tidy up all that mess I did just to see it working. Solve all that in good time now I know what works.
