BFL13's avatar
BFL13
Explorer II
Feb 27, 2021
Renogy DC-DC Charger UPDATE 2 Test
Update--fixed the problem below--you can skip to 4:06 pm post.
Update 2- 28 Feb.
My 20 amper is on, it has the green light and no red light. But it is cycling up and down for amps constantly, making a click when it cycles. The green light sort of flickers and then goes steady and brighter then back again as it cycles. The amps range up and down about 20a as seen on the Trimetric but it cycles back on before amps drop to zero and goes off before amps hit 20 so hard to tell what the max amps is using the Trimetric.
Dip 1,2,3 up and 4,5 down for FLA 14.7v
What is it supposed to do? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
