BFL13
Jun 25, 2021Explorer II
CA Traveler wrote:
It is for sure that larer wire reduces voltage loss and reduces power for a given amps. The resulting power for the output (with device losses) is available at the output with different amps and voltage.
Typo? Reducing voltage drop means higher input volts and so higher watts with the same amps. Output watts is battery voltage at the time (rising while being charged) x amps
Output "battery voltage" will be lower with loads so not clear to me what voltage to use for output watts when not just a battery being charged.
Watts are a PITA! :)
