S_Davis
Jun 30, 2021Explorer
noteven wrote:
You guys are connecting the DC-DC supply cables directly to the starting battery on the vehicle with a fused connection at the battery, right?
I was thinking size large booster cables would make a good conductor.
Marine grade trolling motor 3 pole connectors would be convenient for the cables and the signal wire... these connectors are not that cheep...
That is how I did mine, off the aux battery in the truck. A 120 amp fuse and then 120 amp breaker so I can shut off the charge circuit. For the charge wire I used two 25’ runs of 1/0 DLO cable.
