Roaming54's avatar
Roaming54
Renogy help
When programming the controller it asks for battery amps.
I have 1 deep cycle battery and label says amps 101 is this the number I
Input in controller? Confused
  • red31 may be correct,but I have found that their support and Tech guys are very knowledgeable and very helpful,they will tell you the correct answers.
    Give them a call @800-330-8678
  • Roaming54, use 80 ah for a G24 battery, it doesn't have anything to do with charging.
  • What make size and type of battery do you have?
    Usually they want the capacity in amp-hours at the 20 hour rate.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
