wbwood's avatar
wbwood
Renogy Solar Panels
We have the 100 watt mono crystalline suitcase. I was wondering if anyone knows if you can add another 100 watt solar panel to it?
  • I bought each panel separately.
    I have upgraded the controller 5 times, the last one a good 30 amp Blueskys
  • RJsfishin wrote:
    I started w/ one 100 watt panel, then added another, later added another 90 watt, all three different brands, all near the same voltage, (but not exactly) and all been working good together, no problem.
    you had the suitcase or just the solar panel?
    I.m thinking I would probably have to upgrade the charge controller to maybe a 20 or 30amp...is my thinking correct? it has a 10 amp controller now..
  • I started w/ one 100 watt panel, then added another, later added another 90 watt, all three different brands, all near the same voltage, (but not exactly) all connected in parallel, and all been working good together, no problem.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
