- AridonExplorer
MrWizard wrote:
Boon Docker wrote:
Ten times the cycles, ten times the cost. Works out to about the same in the long run. ;)
yeah but you got to have the up front money to buy them
a long haul investment you gotta hope pays off
not enough years of documented experience to verify all the claims
and whats the difference between these (for RV/marine use)
and cellphone/laptop etc.. that need replaced after only two years and 700=+ cycles
Not too mention the opportunity cost of the money sitting in an expensive system that you will never see a positive return on when taking that into account. People always seem to forget the opportunity cost.
I'm grateful for all the early adopters though. In another decade we should have something worth buying and affordable. - grizzzmanExplorer
2oldman wrote:
grizzzman wrote:
A $1200 battery is much more than cells.
Dang I can pick up USA stock 100AH cells for 112.00 each plus shipping
So 448.00 plus shipping. Is a far cry from 1200.00
I'll bite... where you do get these cells?
Here ya go - brulazExplorer
time2roll wrote:
100AH lithium = 200AH Lead acid as you really should be using just 50% w/ lead acid.
At 100% DoD lithium goes 3000 to 5000 cycles. Lead acid 300 to 500 cycles.
You don't use 100% of Li Ah either. Some risk 10-90% "between the knees" so 80% of Ah available. Others are only willing to do 20-80% or 60% of Ah.
Keeping the cells in sync and within the "knees" is where the electronics is necessary. I wouldn't trust doing it manually.
But yes, generally more life-cycles.
Another issue with lithium is charging when below freezing: not good for the batteries. They can be discharged though. - wa8yxmExplorer IIISome of the info I'm seeing is some of the Li formulas are now costing about the same as T-105 Trojan's. So 10 times the cost... Is no more.
I'd like to see Li technology get down to around the safety and cost of say GC-2's at Costco. - 2oldmanExplorer II
grizzzman wrote:
Thanks. I see they do also sell 12v 100ah battery packs for a few hundred less than the batteries I'm referring to. Makes one wonder what you're getting or not getting. Have to be careful, because you wouldn't want to ruin one just to save a few bucks.
Here ya go - horton333ExplorerFrom what I can tell, still educating myself, the big issue is the cells are not reproducible yet. This means each cell has to be individually balanced or is overcharges and becomes ruined and or overheats and hence the sharing circuitry which has to monitor and control each cell. You buy it ready made with drop in replacement units like Smart Batteries or roll your own which is a lot cheaper and in my case allows me a lot more flexibility on the shape as I plan to use an existing space beside the power panel and it's 2 inches short for an 8D size battery.
wa8yxm wrote:
Where are you getting this?
Some of the info I'm seeing is some of the Li formulas are now costing about the same as T-105 Trojan's. So 10 times the cost... Is no more.. - MrWizardModeratorat this point in time
I'm quite happy with my (5)*135 amp hrs, that cost $350 for 675 amp Hrs of ups AGM Telco/server batteries
I won't be jumping to lithium anytime soon - 2oldmanExplorer III'm happy with 8 AGMs, but not happy about the 400+lb.
What I think will be slick about the Li's is they don't lose voltage at any discharge rate. Run the microwave with no voltage drop? Cool! - Creekside_CampeExplorerThese guys have a pretty thorough review of their lithium system, including the downside:
http://www.technomadia.com/lithium/
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
