RJsfishin wrote:
being as I'm set up to move the polar mount every hour (if I'm around) or 2 or 3, I don't see it helping any.
Rotating it helps less (compared to fixed tilt), than fixed tilt compared to flat. Fixed tilt improves the output by 60% in winter, and 20-30% in summer, depending where you are. You may gain another 10%-15% by rotating it every few hours, but normally it's not worth it.
Also, don't listen to BFL when he says that solar is "all or nothing" and generator is inevitable :). With 120W this is correct because such a panel is a little more than nothing, so to speak. Increasing the wattage 4-5 times with some increase in battery bank is necessary to collect enough on cloudy days to stay put for 3-4 days, until weather improves. "Adjusting" yourself, i.e. your consumption might still be necessary from time to time. In coastal BC there can be more than 4 days of clouds, so ultimately an all-solar RV is difficult thing to accomplish. RV is not a home, and even in a solar home you have to adjust your consumption - which doesn't necessarily means sacrificing something, but replacing some devices, and keep an eye on it, to be able not to use generator. It's not that people "can't", it's that they don't want.
