pianotuna's avatar
pianotuna
Nomad III
Nov 14, 2015
renology controller
Hi,
Any one know if the 40 amp mppt has adjustable set points for bulk and float voltages?
If so, how is the magic accomplished?
  • JiminDenver wrote:
    Hi Don
    EP solar has a industrial MPPT controller in 30/40 and 60a versions. The even have a diversified load control. YOu can find the specs of all the tracers on this site.
    click
    The E series comes in 45 and 60a flavors with many of the same features of the I series.
    click
    I would believe these are the specs to the A series that Renogy is using. It is limited to 100 Voc.
    Click
  • Hi Don
    click
  • rjsurfer wrote:
    Not adjustable, I have two of them.
    Works fine for my 4 T105's
    I'm running 700 watts up on the roof and my specific gravity is always spot on and I'm adding water to the batteries maybe once a month, a simplistic way of checking for overcharging.
    Ron W.
    That still indicates a degree of "overcharging" though. Might be a little tough on the positive plates shedding too soon or whatever.
    I was having that sort of water use this summer with about half that much solar on four 6s during a stretch of sunny weather. Batts got to Vabs mid-day which left a long time till dark. Had to reduce time at Vabs and go to Float voltage earlier, which stopped so much water loss, while still getting the batts to "true full" before dark.
    Perhaps with the non-adjustable profile that has the two-hours at Vabs, the way to go in long periods of sunny weather would be to disconnect some of the solar, so it takes longer in the day to get to Vabs but you still get to full before dark. Then when it comes to a cloudier time, reconnect all 700w.
    BTW, the actual method with my Eco-Worthy controller was to reduce the "Float" voltage setting to 13.6 from 14.5. That controller has no time at Vabs. It goes to Float as soon as you get to Vabs. So you have to pick a Vabs sort of voltage for the Float setting to get any time at a Vabs. Your level of Vabs would depend on how much daytime is left in that period. Leave it high if time left before dark is shorter.
    Solar is not a fire and forget system when the weather changes a lot where you are camping.
  • Not adjustable, I have two of them.
    Ron W.
  • pianotuna wrote:
    Hi bfl13,
    I was hoping you might chime in. The manual doesn't cover adjusting set points--but I think you have done so?
    That guy from Ontario who has unfortunately since dropped out of the forum got one last spring and some info came out then. The basic unit has a fixed charging profile --standard EP solar one with three stages with two hours at Vabs then float.
    To do adjustments you need the remote gizmo and ISTR you do it with your laptop? Can't remember. ISTR that was only with the new Tracer and its new gizmo. There was an older Tracer with its older remote, so you have to be sure which one you are looking at.
  • Hi bfl13,
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
