time2roll
Feb 17, 2015Nomad
If you put your big inverter (1000+w) on the chassis starting battery and use an extension cord to power your 30 amp charger you will gain the advantage of putting the proper voltage for fast charging direct on the house battery. Keep the engine running or the chassis starting battery will quickly become overly discharged.
This is a good plan in the scheme of things. Effective and low cost.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
