time2roll
Feb 18, 2015Nomad
Naio wrote:Of course. Just put your voltmeter on the battery terminals. If you are dropping to 12.3 or less it is probably time to unplug. Check at 20 minute intervals the first go.
Can I get an accurate reading of the chassis battery's SOC while the inverter is hooked up and the engine running? I am guessing no, that there would be a surface charge that would fool my voltmeter.
Fingers crossed you never go below 13.5 volts indicating the alternator is covering the full amount. Maybe give it a go before the actual trip.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
