Home_Skillet
May 26, 2013Explorer II
You would need to remove the steering gear box to check for any broken off bolts.
The bolts probably got loose over time, causing them to break.Or, someone must have worked on the steering and left the washer off.
Make sure you go back with the OEM bolts and washers.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 11, 2026
