recycler
May 26, 2013Explorer
look and see if the end of the broken bolt is sticking out..if it is see if you can thread it out that way if not you will have to pull the box from the frame to remove it.. should be simple enough if you have a long half inch breaker bar and a torque wrench... and replace the other bolts while your there have a feeling they are not far behind..
