BFL13
Oct 22, 2014Explorer II
The voltage that counts is the loaded voltage it gets down to when you try to run something. That's when voltage drops below inverter low voltage shut off. However,
The fancy inverters like yours have other settings that might be at play here, and there can be things go wrong between inverter and its remote too based on some reports here on the forum. I don't have a clue about that side of things, sorry.
Maybe the repair crew messed up your settings. Or
Does anything work at night that should work from the inverter? If only the receptacles don't work but the microwave does work, then it's about the distribution of the 120v output from the inverter to the rig. Maybe it didn't get put back in right when it was out for repair.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
