time2roll
Oct 25, 2014Nomad
Inverter should run fine down to at least 11.0 volts. Most run to 10.5 or 10.0 before they shut down. Any chance you have a low cut out voltage that was adjusted too high?
12.4 volts is not over discharged. Do verify the voltage right at the inverter.
Otherwise I recommend GoPower sine wave.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
