23hotrodr
Sep 25, 2013Explorer
repairing a Suburban furnace
I need to work on a Suburban furnace model SF35 and am not sure how to go about it. When I remove the access cover on the outside of the RV, I cannot get access to very much in the furnace and nothing is accessable from inside behind the cabinetry.
It appears that there is one screw at the base of the blower housing that can be removed and will allow the entire guts of the furnace to be pulled out. The 4 wire connector underneat the cabinets must be disconnected and the gas line disconnected at the furnace.
Is this correct? Does one gain access to the burner area and most other stuff in the furnace by pulling it all out and working on the guts on a bench?
I believe I have a bad ignition control board that is accessable without removing the entire guts, but I also want to make sure the ignitor, flame sensor and burner are clean and correct.
Thanks for any advice you can give. It seems like I always have to learn things the hard way!
Thanks-- Mick
Thanks-- Mick
