ScottG
Sep 05, 2018Nomad
theoldwizard1 wrote:
I am not a professional HVAC tech, but I think ScottG is over reacting.
Brazing in an appropriate low side port does make a proper torch and the skill to braze. If you are going to add a low side, you might as well add a high side. Now you need to buy the correct gauge set and a vacuum pump. Now find the leak.
The Harbor Freight Gauges and vacuum pump work, but they don't seem to last a long time.
I am lucky in that I have a neighbor who's son is a pro. If I do the hard work, he will do the "technical" part.
I suggest before the OP wastes a lot of money of equipment and gas, he should call a real HVAC tech and let them know the unit was stored with the freon leaked out (and therefor the sealed system is open).
Then he can put the money towards a new ac.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
