wa8yxm
Sep 06, 2018Explorer III
joeshmoe wrote:
Have a lightly used Coleman Mach that I replaced after only a couple years (It actually began dying the first year). It sprung a leak shortly after I purchased the camper, and all the make-it-cold stuff eventually came out. I've looked around and found a few pages about repairing these things. Apprently, installing one of those "saddle" valves after the repair is made almost always end up leaking. So soldering in an low pressure valve is the "proper" way to repair these otherwise unrepairable units.
Best option on those is always replacement.
However if the leak is in a location where it can be totally and completely fixed and properly sealed.. (There is something called a vacuum test.. you suck it down and leave a meter attached. 10 or 15 minutes later if the needle has not moved..> GOOD. note you need to suck it down anyway for like an hour or more.
I have installed a couple of saddle valves on other stuff.
never had one leak. NEVER.
OH. one final comment on Coleman A/Cs.. My Service tech says "They Suck" but she means it in a good way
The rooftop unit sucks air in via the condenser. that means that all the "Crud" that eventually blocks the air flow collects on teh OUTSIDE of the condenser.. Remove outer cover. peal or brush off, replace outer cover.
Others "BLOW" so you have to remove outer cover. Remove INNER cover (Varies from a few screws to a jell of a hob) With my tiny hands (XXXL) I have to remove the fan. then I can get in and clean it..
I LOVE MY COLEMAN.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
