joeshmoe's avatar
joeshmoe
Repairing A/C, Leaked All Refrigerant
Have a lightly used Coleman Mach that I replaced after only a couple years (It actually began dying the first year). It sprung a leak shortly after I purchased the camper, and all the make-it-cold stuff eventually came out. I've looked around and found a few pages about repairing these things. Apprently, installing one of those "saddle" valves after the repair is made almost always end up leaking. So soldering in an low pressure valve is the "proper" way to repair these otherwise unrepairable units.
I just hate to toss the thing. It has very little use. It's practically new. I'd like to at least see if it's possible, and get a few bucks for it to offset the cost of the new one I purchased.
Thoughts? Is it worth it or even doable?
  • What year A/C? Old may take R-22 Freon, newer 134A Freon. Easy to solder new valve to charge system. You will need a vacuum pump and a A/C manifold gauge set. Any quality A/C guy should be able to repair. About $140.00-$250.00 estimate. Any remaining Freon can not be emptied in the atmosphere. If you do the work, wear safety glasses.-Good Luck
  • If it has sat in an empty condition then it's toast. They need to be fixed quickly otherwise moisture is obsorbed into the system and forms acid when it mixes with the remains of the freon. Then it destroys everything in its path.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
